felcunha
Objects not converted when saving back from AC22 to AC21
Hello all,
I've encountered problems when saving backwards a project from AC22 to AC21. All objects, windows and doors don't convert and are missing in AC21. All I get are the trees.
I suppose it's a bug, very annoying when I have modelled all in AC22 and have to exchange with fellows in AC21.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
3 Replies 3
Guru
Existing thread about this: https://archicad-talk.graphisoft.com/viewtopic.php?f=12&t=61677&p=284055&hilit=backwards#p284055
Not the most ideal solution, but it works.
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
If the object uses commands that are new in version X then, when downgrading to X-1, the objects will be "broken" - they will downgrade, but due to the content they will cause errors that finally will show a "dot".
Piotr
Guru
Given that every type of door and window fails to convert, rather than fail to generate, I figured it was more the fact that they did not script in the backwards convert for many of the basic AC22 objects... I have not noticed any differences in them from AC21. I do not recall having this issue saving v19 from v21.
Ling.
