Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Objects
I got some objects from BIMcomponents and I want to paste or dumpt them at the archicad library or embedded library to be use later, how do i go ?
2 REPLIES 2
Have you downloaded them into your Project File yet? If so, they should be located in the Embedded Library already.
You can them save from the embedded library into any folder into your hard drive so you can them load them into other projects as linked libraries.
No , I did not download them , I pull a bounce of them up from google right on the interface , I click on those I like and ( SAVE as ) with a file name xyz . Well i think i just go ahead and download as you suggest.
