Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Street address on the Wall
How do I insert a name to a wall module ?
6 REPLIES 6
I have moved this post to a more appropriate section of the forum and removed the poll - it is not a wish for Archicad.
I am not sure exactly what you want.
Do you want to show the wall name in a label?
If so place the name in the wall ID and label the wall using the ID label.
Barry, I mean ( 1234 uptown bvld ) printed on the wall in front of the house.
David Maudlin
sampson:
One option is to use the Text 3D object.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
How do I print ( 1101 someday lane ) in front of a design building ?
Erwin Edel
https://bimcomponents.com/GSM/Details/17772
as an example
https://bimcomponents.com/Search/street%20sign for a quick search
Or just use 3d text object from the library.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Sampson,
There is no need to repost a question for which you already have been given the answer.
If you need more information or do not understand the response then please continue with replies in the original post.
I have merged your two topics.
