Old INT and USA Libraries (AC9 - AC4.55)
Since each version since AC 10 contains migration libraries, old libraries are needed only for AC 9 and earlier:
http://www.graphisoft.com/downloads/library/int.html
http://www.graphisoft.com/downloads/library/USA.html
TDabney
I know this is a SUPER old post, but I am trying to track down the ArchiCAD 8.0 library so I can open a project done in AC 8.0 and have the associated library parts show up. It seems I have saved all the old ArchiCAD libraries back to 6.5, except the 8.0 library, which is of course the one I need...
The links from Laszlo's post above, no longer work...
I actually have the original ArchiCAD 8.0 install disk, but don't have easy access to a computer that will run it - maybe it's pre-intel chip? (I'm on Mac OS).
I wish older projects (mine go back to ArchiCAD 6.5) were a little more future proof... This is a PITA.
Thank you,
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
Lingwisyer
Guru
You can always archive completed projects after a couple of years with all of their associated library parts. Your files will be a bit larger, but then they become independent of any external libraries.
Ling.
