Old Library Parts
Seiss Wagner
I have collected a number of old and useful non-Graphisoft library parts from the AC 6.5 & 7 days. Can I safely use these old library objects with AC 9?
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
4 REPLIES 4
Stephen Dolbee
Our older library parts work fine.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
TomWaltz
We have a few dating back to 6.5, that seem to work fine in 9
Tom Waltz
Our office has recently upgraded to ArchiCAD 9. We are using a symbol from v6.5 and the symbols are reseting. The symbol from v6.5 is a keynote: circle with a text # inside. These are reseting to default (text :#1). This is the only library part that is affected.
We continue to lose this information periodically. Any suggestions to rectify this issue?
I also use a number of library parts created in AC 6.5.
Perhaps superstitiously, I have, at the desktop, duplicated each part,
put the duplicates into a new folder, opened each one in AC 8.1, corrected
any parameter settings that are wrong (line types, fill types, etc.)
and saved.
This updates the parts and gives them the subtype data and obligatory
parameters of a native 8.1 library part.
In AC 9.0, just to be "safe", I go through the same process.
This may be nonsense but it might cause some file updating
that fixes problems with objects created in earlier versions.
Thank you,
Peter Devlin
