PARENTHESES in GDL
In GS scripts for windows I have find following line:
dim stOpeningDir[]
stOpeningDir[1] = `Inside`
stOpeningDir[2] = `Outside`
values "gs_opening_dir" stOpeningDir
bOpeningDirection = (gs_opening_dir = stOpeningDir[2]) !GS writes so
end
! Above script can be written also so:
dim stOpeningDir[]
IF gs_opening_dir = "Outside" THEN bOpeningDirection=1 ELSE bOpeningDirection=0 !Written by me and is same that GS has wrote
END
So that's all means that PARENTHESES have another additional function like "Special" IF Statment for Integer values.
I'm I right, or not?
5 Replies 5
I am not entirely sure what it is that you are trying to say, but square parentheses [] are reserved for arrays.
Frank Beister
The expression
is boolean calculation. It's a comparation with boolean results: =1 true, =0: false.
Using this you can reduce some complex IF-THEN - constructions.
E.g.:
! opening: "single","double"
! display_opening: "no","first","all"
selection = (opening="double")*3 + NOT(display_opening="no") + (display_opening="all")
GOTO 200 + selection
Result:
selection=
0: single opening, no opening lines
1: single opening, show opening lines
2: single opening, show opening lines
3: double opening, no opening lines
4: double opening, show first opening lines
5: double opening, show all opening lines
So YES, you are right.
Frank Beister
The boolean operations have a lower priority than addition or multiplication (below "PUNKT VOR STRICH", you should understand that 😉 ). So you have to put paranthesis around it. The paranthesis itself (in this case) do not have another function than in a calculation like (3+4)*5 to get 35 instead of 23.
Vielen dank F.Beister,
perfekt erklärt!
I will save your reply as tip in my PC, until "Next Generation" GDL Manuel. 😉
Gruß
