‎2003-12-29 07:43 PM
‎2003-12-30 12:09 AM
‎2003-12-30 09:25 AM
‎2003-12-30 11:42 AM
PWD wrote:
I placed the PRINT command in the "root" as you advise me to do, but it does not work...
AC8 recognizes it as an error not as code (that is ok) but at execution time...It give me the message: "Danger, you encountered problem during the last operation".
After that all is ok.
It's strange.![]()
Thank you
PWD
‎2003-12-30 12:13 PM
You should not use the Print command except for debugging your scriptOK David,
‎2003-12-30 12:17 PM
PWD wrote:If you posted the offending part of the script here, it would be easier to help?You should not use the Print command except for debugging your scriptOK David,
but PRINT does not work in debugging mode, too.
I can't use it neither for my uses...
I agree that It's annoying for the user...![]()
‎2003-12-30 01:24 PM
PWD wrote:I normally make it a policy not to reply to people who use anonymous handles, but will do because you are from Parma, and your football team and town are in trouble, and you need help from anyone who can provide it.You should not use the Print command except for debugging your scriptbut PRINT does not work in debugging mode, too.
‎2003-12-30 03:27 PM
but will do because you are from Parma, and your football team and town are in trouble, and you need help from anyone who can provide it.Not only my football team, but PARMALAT also...
‎2003-12-30 04:53 PM
PWD wrote:but will do because you are from Parma, and your football team and town are in trouble, and you need help from anyone who can provide it.Not only my football team, but PARMALAT also...![]()
I use this handle now cause I used this since 7years an so this is my name for all... for my friend also.
In any case you know my real name...: I'm from Parma and I received your cookbook about 1month ago, I paid using a bank tranfer![]()
Do you remember?
‎2003-12-30 05:03 PM
