‎2012-05-23 09:06 PM
‎2012-05-24 02:33 AM
‎2012-05-24 02:41 AM
‎2012-05-24 06:52 AM
‎2012-05-24 01:14 PM
‎2012-05-24 10:40 PM
Erika wrote:Thanks. How odd that they would remove something like that!
Actually, I had checked the 14 and 15 INT library parts, and it is a parking library part in 14, but not 15.
‎2012-05-31 04:21 PM
Erika wrote:Exactly!... by the way, thanks everybody for your replies! I haven't been able to reply to you guys earlier. I sort of worked my way around so I could add the polyline object from archicad 14 to archicad 15 without having to add the whole library. In case anyone is interested, this is how I did it. Opened a new file in archicad 14, placed the object, then saved as ".pla" so that only the object would be saved and not the whole library. Then opened it and extracted the object so I could take just the object and macros folders (the others are not necesary and will give you error reports of duplicate parts). Put those 2 folders inside another folder, named it after the object and that's it.
