Parking Place Polyline 15?
Hi, I can't seem to find the Parking Place Polyline in archicad 15. Was it deleted? and if so, is there a way to import it from archicad 14 without having to load the entire archicad 14 library?
thanks!
6 REPLIES 6
It“s here:
ArchiCAD Library 15 / 2.2 Site Improvements 15 / Park and Street 15 / Parking Place 15.gsm!!
Erika Epstein
you can load the individual part from 14 by load from file dialogue box, see screenshot
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Since MOS3JOKER said 'polyline', I'm guessing the he/she had a custom linetype in an earlier file rather than an object?
MOS3JOKER - if it is a linetype, simply go to Options > Attributes > Attribute Manager, switch to the linetype tab. On the right, open your prior 14 file and find the custom linetype you need. Select it and then if on the left the index number shown is not in use, select Overwrite; otherwise select Append. OK out to save the linetype in the current file.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Erika Epstein
Actually, I had checked the 14 and 15 INT library parts, and it is a parking library part in 14, but not 15.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks. How odd that they would remove something like that!
Exactly!... by the way, thanks everybody for your replies! I haven't been able to reply to you guys earlier. I sort of worked my way around so I could add the polyline object from archicad 14 to archicad 15 without having to add the whole library. In case anyone is interested, this is how I did it. Opened a new file in archicad 14, placed the object, then saved as ".pla" so that only the object would be saved and not the whole library. Then opened it and extracted the object so I could take just the object and macros folders (the others are not necesary and will give you error reports of duplicate parts). Put those 2 folders inside another folder, named it after the object and that's it.
Thanks a lot guys! Sort of new to these forums so I hope this wasn't asked before
EDIT: I haven't tried it yet but it seems Erika's method is WAY simpler than mine. I'll try it later. Thanks!
