Picture Size inquiry
Nader Belal
Mentor
Hi there,
Is there a way that I can extract the picture size (in any type of units) through GDL ?
Thank you in advance
A good friend of mine have once told me that I“m so brute that I“m capable of creating a GDL script capable of creating GDLs.
Nader Belal
Mentor
I will answer this to all,
The short answer there isn't, except if for when the picture was applied to a element as a textuew/surface
1 REPLY 1
Nader Belal
Mentor
