2016-04-02 05:39 PM
2016-04-03 04:43 PM
2016-04-03 04:51 PM
2016-04-03 04:53 PM
SmileyMan wrote:Unfortunately no, I have never heard of them.
Do you know what file contains the PIIROINEN surfaces? I'd completely remove that file/object/library from my entire system and server, but I can't find it using the search function on my computer.
2016-04-03 05:23 PM
2016-04-03 05:45 PM
2016-04-03 05:58 PM
David wrote:In the past?! Yes it is possible.... but I have no such file on my computer or any of my AC files anymore. How can I still be getting spammed? Are these surfaces imbedded in anything else?
SmileyMan:
To echo Ted's comment, look for Piiroinen Furniture Library.lcf in the Library Manger. I used this library on a project and in the Surface Settings dialog box and Attribute Manager they show with anitalicizedname indicating they are created by a GDL Object or macro.
2016-04-03 06:10 PM
2016-04-03 06:49 PM
David wrote:David, as noted below, I've done this multiple times. As a matter of fact, I have been screwing around with this problem for over a year!!!! I will have everything "clean" with no issues, then after about a week or so I will open a file, and all these surfaces re-appear! There has GOT TO BE another file/object/linked library other than the PIIROINEN library file that has these surfaces inside them.
SmileyMan:
Once this library has been loaded, those Surfaces are added as attributes to the file (so will remain even after the library is removed). If a new project is started with the "Use Latest Project Settings" option, then these attributes will appear in the new file. So try deleting the Surfaces from your template file, and start new projects from this template file.
2016-04-04 01:49 PM
