2005-03-16 08:37 PM - last edited on 2023-05-24 12:49 PM by Rubia Torres
2005-03-16 09:55 PM
2005-03-17 01:49 AM
Joeri wrote:Yes, It use to work . You can also activate Special Menu by regedit: HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD\ArchiCAD 9.0.0 INT R1\Special Menu=1.
I used to have an interesting trick in ArchiCAD 6.5 (WINDOWS platform) to place all library objects on the floor plan by once, while holding the SHIFT button starting the program. Recently I discovered having problems to do so in ArchiCAD 9. Who can help to find the way to return to this easy tool in version 9? WIN XP or MAC OSX ? It would be of great help while re-assembling my personalized libraries. Thanks
2005-03-17 10:24 AM
2005-04-16 02:21 PM
2005-04-18 05:24 AM
mbwolf wrote:
Hi
after doing some searching I think this thread may relate to what i am trying to do and would appreciate some clarification & assistance.
The Aust Essential libraries.pla contain parts which have some sort of script/code errors (you may be placing this library part on the wrong layer Error >>>>>) comes up each time you change windows Twice for each part affected. The only solution i have thought of is to delete these parts from the library so they are not available for use until GraphisoftAust fix these. Sample Objects File Attached
So my question is to re-Archive the library do i place all of it on a drawing & if so Is there a way to do this on MAC. The special menu is available in preferences work environment but is empty and won't show on the task bar.
Then again i may be completely on the wrong track.
2005-04-18 05:39 AM
2005-04-18 06:59 AM
Barry Wrote
You will need to extract the PLA library into one that you can edit (open the PLA file and you will be promted to do this).
You can then either edit the scripts of the offending parts (comment out or delete the first 3 or 4 lines in the master and or 2D scripts - you will see it mention wrong layers, so it will be very clear what to get rid of), or you can modify the "maste GDL variable" file to reflect the layers in your current project.
If you want to continue using a PLA file then you will need to re-archive the file with the library
2005-04-18 01:52 PM
mbwolf wrote:
The Extraction is done & have edited out known faulty lib parts but this still leaves me with How do i place all objects on a plan using Mac OS X to Archive & is this the way to tackle this situation
2005-04-18 08:03 PM
mbwolf wrote:Special menu.
