Place windows so that they align with interior wall surface?
Im trying to place windows that open outwards and that are anchored to the interior surface of the wall. At the moment they only seem to anchor to the side of the wall that you declare as the exterior which means that I need to manually offset the revel to make them align with the interior.
Is it possible to set the interior face of the wall as the revel anchor point?
thanks
Dontknow
You mean like my window in the wall on the right, placed on the inside of the wall?
You can place it directly on the inside of the wall:
or set the reveal of the window.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Im guessing you mean using the little sun symbol to choose which side of the wall? But if I do this then it means my window is facing the wrong way and the sun shade will be placed inside the building!
Is there a way to align the window reveal to the interior surface so that the window orientates correctly to the outside and so that I dont need to manually enter an off set measurement for the reveal??
I just want the window to align automatically to the interior surface and face outwards. In France this is how most windows are installed.
Dontknow
Ah, I see.
When you're using sun shades I think the only way is to work with reveal.
ArchiCAD 25.
