Placing custom window on a wall
I can not to edit the symbol of a archicad 12 window, it does not have a 2d script!! and I gave up...., so I am making my own window as a 3d model and I can easily edit the 2d symbol. .. the problem is when I place the window on the wall it looks good on floor plan but in 3d view the window is outside the wall.. ^&%$^&%!!!
( I will have to create every different size window, because if I make it bigger, the jamb will distort ..) anyway, for now i just want my window to be in the wall , not sticking out .
Does anyone knows how to create a smart/stretchy object ??
any books out there??
Thanks,
Carmen
19 Replies 19
Well I guess it makes sense now. The project origin is 0,0,0. Correct me if I'm wrong...Autoscript uses the project origin as 0,0,0 in the script. I guess we don't think about plan views having a Z direction because we are looking at onlly 2 dimension. That would explain...
Peter Devlin wrote
I once made a window on a story that was 100 feet below story one and when I placed the window it showed up 100 feet outside of the wall.
Doug
Hello Doug,
You wrote:
"auto script places "Z" zero at the center of the wall and
builds the window from there outward."
I just re-read the GDL manual about "Special Instructions for
Doors and Windows". In the General Guidelines section it states:
• When constructing the door/window in the floor plan window,
visualize it as if you are looking at it from the inside of the wall it will be
inserted into.
• Think of the project zero level as the external surface of the wall.
• Elements that should be inside the wall, like the window frame, should be above the zero level.
• Door panels opening to the outside should be below the zero level.
Note the second statement, "zero level as the external surface of the wall",
not someplace in the thickness of the wall. Thus, if you want the outside
face of the jamb to be flush with the outside surface of the wall then
in the plan model, as seen in section, the outside surface of the edge of
the frame should be placed at Z=0. I don't understand how you can
get things to work any other way than as described above.
Thanks,
Peter Devlin
Good morning Peter,
Well, I'm not sure exactly why that window worked last night. After reading your post this morning I created several different windows trying to recreate that scenario. What I found was that you are absolutely right. No matter what I did I could not get a window that was created centered horizontally on the z axis to place correctly in a wall. Actually, you can change it using the "Sill" construction method. Maybe it was set to that. Thanks for making me take a second look. The last thing I want to do is give someone the wrong information.
Thanks again,
Doug
Hello Doug,
Thanks for posting back. I was one worried man last night
wondering if I had not understood the basics of making
a door or window in GDL.
Peter Devlin
Stress Co_
Hi Peter:
Any idea why my custom door when placed only partially shows? It's sliced by a diagonal line.
(It's been a long time since I've created a custom door)
Marc Corney, Architect
Red Canoe Architecture, P. A.
Hello Marc,
That is indeed strange. Do you recognize what appears to be
another type of door panel on the other side of the diagonal line.
I am assuming that you modeled a complete door, frame, and trim
in the floor plan and saved as a door because you seem to have
prairie style trim and a cleated door panel. It's as if you have
a custom door panel enabled as well as your modeled panel.
I have never seen this before. I do not do many auto scripted doors
or custom door panels
Peter Devlin.
Stress Co_
Thanks for the reply Peter.
The lines to the right of the diagonal are a window on a wall in the background. Actually, I only modeled a door panel, which I then
placed as a custom panel in a D1 12 DOOR.
I may just do a 2D patch as I'm a bit pressed for time.
BTW, Looks wrong in the preview too.
Hello Marc,
Have you tried to open your custom door panel via file->Libraries and objects
->open object and navigate to the folder that contains your custom door
panel and select and open it to see in the GDL editing environment's
3D view if the panel is cut in the same way as you see in the preview
and the elevation ?
Peter Devlin
Stress Co_
Ahh, thanks Peter.
Looking at the 3D editing enviro. made me realize I created the door in plan with a rotated grid. All is now as it should be.
Djordje
It is also essential that the project origin 0,0,0 is at the middle of the bottom of the door.
Same for all the objects that you create from the plan. ALWAYS model them so that the default insertion point is at 0,0,0
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
