Polygon Operations documentation error
s_p_b
Just want to note this as an error in the documentation for PolyOperations:
ch = INITADDONSCOPE ("PolyOperations ", "", "")
The innocuous space after "PolyOperations" prevents the channel from opening. I spent quite some time trying to understand why my project wasn't working. Just be wary if you're copying commands directly from the GDL reference!
5 REPLIES 5
It is correct when I looked at it in the 26 reference.
Which version are you looking at?
@s_p_b wrote:
I am using the online documentation:
https://gdl.graphisoft.com/reference-guide/polygon-operations-extension
@Peter Baksa ,
Is this anything you can get fixed please?
Peter Baksa
Sure, done.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
Thanks Peter.
