tsturm
Problem with AC 8.1 Curtainwall Double Door in PLA library
Still not sure about how to attach images. Hope I did it right.
Problem here is with a AC library part which is in a PLA library.
I know how to open the library into a folder of parts. I know how to correct the problem of the part. (Which I am pissed that GS did not check was correct before including with AC).
I want to know if it is possible to edit the part in the PLA file or if I need to explode the Archive file to edit the part. If I need to do this, then how do I save the library back as a PLA after fixing the door part. I was hoping to keep the ArchiCAD 8.1 library as a non-editible library. However, the Curtainwall Double Door needs to be fixed as it was issued with mistakes. See the image if it attached correctly.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
Djordje
Just save the file with the exploded library loaded as folders to PLA. Then it can be used a source.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
