‎2008-02-20
11:14 AM
‎2023-05-24
12:02 PM
Rubia Torres
‎2008-02-20 11:07 PM
‎2008-02-21 01:54 PM
‎2008-02-21 03:59 PM
‎2008-02-21 04:33 PM
"David Maudlin" wrote:
hariz:
Just a guess: under Parameters > Floor Plan Symbol > Symbol Fill Background what is the setting? This does not occur with the default settings in the Object Library 11.lcf, so without knowing all the door parameter settings, it is hard to diagnose.
HTH
‎2008-02-21 05:11 PM
‎2008-02-21 07:52 PM
‎2008-02-21 07:53 PM
‎2008-02-22 03:48 PM
"Joeri" wrote:
David,
As I see your signature you have the US version installed on your system?![]()
AFAIK INT library does not show up the necessary parameters. Most of the doors and windows I like to use have a hardcoded background color pen 19. It's a solid fill (to be set white..)
Make pen 19 to a different color and you have the problem !
‎2008-02-22 04:37 PM
hariz wrote:hariz:
Yes, I guess I have US version, but I'm not completely sure about it. Anyway, I don't have this "Floor plan symbol" option in Parameters section only "2D Representation".
