2005-01-18
08:45 AM
- last edited on
2023-05-24
11:05 AM
by
Rubia Torres
2005-01-18 01:49 PM
2005-01-18 08:08 PM
laszlonagy wrote:Attached is an example of what I was speaking about. This is the D2 Sliding Library part. Notice the ArchiCAD 7 library part the door panels are drawn with the correct overlap and detail for the door panel selected. This accuracy also carries through to the 3D. In the ArchiCAD 8 & 9 library part the panels are drawn wrong in plan and 3D. They should have more detail (like the ArchiCAD 7 symbol to reflect panel choice) and they should overlap instead of touch at the corners like real sliding doors. I didn't go through and retest all of the symbols but from what I remember this problem effected every slider in the library under: Object Library 8 or 9 -> Special Doors 8 or 9 -> Sliding Doors 8 or 9. I use the Mac OS X platform and have the latest versions of all three ArchiCAD Versions.
Could you be more specific?
Could you post a screen shot and show the problem on it?
2005-01-18 08:51 PM
