2004-03-17 07:10 PM
2004-03-17 07:35 PM
2004-03-17 08:13 PM
Karl wrote:A partial workaround is to use cutting planes in 3D and/or the Special menu item "Use section in 3D".
This is a known bug with the marquee and stairs. AFAIK there isn't a satisfactory workaround - the stairs and landings only show if the entire stairs are inside the marquee.
2004-03-20 12:30 AM
2004-03-20 02:41 AM
David wrote:If this had worked, you would keep your original stairs as only they are editable to adjust the stairs. You'd want to put them (or the non-editable object) on different layers so that only one or the other is showing as needed. If you need a different binary object again, just save the real stairs again as below.
Thanks for your advices Karl and Djordje.
But now I have other question, for Karl: How can I save the stairs as Binary object, I mean I need to make again a new stair...?
2004-03-20 04:03 PM
