Red
Projecting a fill?????
I have an object that the 2d view is projected. This maybe a stupid question. What I want to do is place a fill in 2d view, so can I fill read off the projection to make it an easy fix? I don't believe it’s possible but I wanted to here it from some gurus.
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
7 Replies 7
Djordje
It is possible, using the PROJECT2 codes in the 2D script.
Have to check exactly what they are, and will come back before someone else beats me to it Don't have the docs handy ...
However, expect long regen times.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Dwight
THE 2D SCRIPT SHOULD READ:
PROJECT2 3,270,2
EXCLAIM OUT THE REST OF THE CODE, IF ANY.
FROM PAGE 125 OF THE GDL REFERENCE
Dwight Atkinson
Red
Normal Fill
if rf then
add2 0,-b/2
set fill JF
poly2_b 5, 2, JP, 91,
0-O,0,1,
a-T/2,0,1,
a-T/2,b,1,
0-O,b,1,
0-O,0,1
endif
Projected FIll
I'm guessing a projected fill would be scripted like this??
if rf then
add2 0,-b/2
set fill JF
PROJECT2 3, 270, 2
endif
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Red wrote:
Normal Fill
if rf then
add2 0,-b/2
set fill JF
0-O,0,1,
a-T/2,0,1,
a-T/2,b,1,
0-O,b,1,
0-O,0,1
endif
Projected FIll
if rf then
add2 0,-b/2
set fill JF
PROJECT2 3, 270, 2
endif
No,
Just put in
PROJECT2 3, 270,2
no poly2 is needed.
I don't think it's possible while we don't know the 2D shape.
Djordje
PROJECT2 does the 2D projection of the shape(s) defined in the 3D script.
Djordje
HP Omen
LiHigh
Just use:
PROJECT2{2} projection_code, angle, method
[, backgroundColor, fillOrigoX,
fillOrigoY, filldirection]
Howard Phua
Win 10, Archicad 19 INT
