PsynOpenProfTube free
26 REPLIES 26
material now follows the path. still a slight distortion when the curve has a large rise
https://youtu.be/bQE5pv80_5M
Hmooslechner
me too - there is not much time for this coming.. but lets see..
fixed a couple of things
Moar updates, alternate tube style for using an image as a fence or rail, etc
vid
https://youtu.be/3WW5X7Q8FIc
alemanda
THANK YOU!
It's a great object indeed!
I have a problem with that. I cannot reproduce what you show in your last video. If I reduce the points of the section to 2 I jst see the polyline path and not the tube.
Further more I have 2 comments
1. I think that the user should have the possibility to set a custome starting and ending section cut, in order to have it perpendicular or cut with a particular angle. Probably it is quite difficult to implement when these segments are curved ...
2. One (of the most) important use of this amazing object is for trims. It seems it is not possible now to have the 1st segment vertical. Also It would be very nice to freely rotate the whole tube in 3D.
THANK YOU AGAIN
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
alemanda wrote:
THANK YOU!
THANK YOU AGAIN
In my video the fence is actually still a box, i just made it 4' tall and 1/8" thick.
free rotate has now been added and ill get those custom angles done soon too. much easier than you think.
alemanda
SenecaDesignLLC wrote:
... much easier than you think.
I'm sure of that!
You don't know how much time I spent to get the result you got with the dynamic polyline ... but without results ...
Thanks
AC27 latest hotfix
Win 10 Pro 64bit
