2016-01-21 07:27 PM
2016-01-23 09:59 PM
2016-01-24 05:30 PM
2016-01-25 04:59 AM
2016-01-26 08:51 PM
2016-01-27 09:17 AM
2016-01-28 04:46 PM
alemanda wrote:
THANK YOU!
It's a great object indeed!
I have a problem with that. I cannot reproduce what you show in your last video. If I reduce the points of the section to 2 I jst see the polyline path and not the tube.
Further more I have 2 comments
1. I think that the user should have the possibility to set a custome starting and ending section cut, in order to have it perpendicular or cut with a particular angle. Probably it is quite difficult to implement when these segments are curved ...
2. One (of the most) important use of this amazing object is for trims. It seems it is not possible now to have the 1st segment vertical. Also It would be very nice to freely rotate the whole tube in 3D.
THANK YOU AGAIN
2016-01-28 05:35 PM
SenecaDesignLLC wrote:I'm sure of that!
... much easier than you think.
