Nader Belal
Mentor
Question about arcs curves and Primitive elements
Hi there,
I would like to ask you how do you define a curved edge of a body using vert edge and pgon ...
I mean if you used Edge and defined is as a curved edge, for sure there are an infinite number of posibilities for the arcs radius .... how do you define that ?
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
2 Replies 2
When I need to use primitives I try first prototype the model using morph tool...(with the easy to manage data) and then do a cleanup in saved script.
Piotr
Nader Belal
Mentor
@Piotr Dobrowolski
Thank you, I will try it out
