2 weeks ago - last edited 2 weeks ago
Trying to import either RFA or RVT files from two different sources for some commercial vent hoods. The correct processes were followed for each, so that's not the issue.
In each case, I got an error message, saying that the file "could not be imported".
"Try checking the file with the original author to solve the problem, and please be aware that only file versions 2015-2024 are supported."
Has anybody else run into this? These are files downloaded directly from the manufacturer and / or BIMObject.
Solved! Go to Solution.
2 weeks ago
The answer is in the message.
The files are probably in a format older than 2015 or possibly in 2025 format, which Archicad can not read.
2 weeks ago
You can apparently check the version of RVT files by opening them in Notepad or similar and searching for "b u i l d"
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2 weeks ago
Hi! I have also encountered this issue with some supplier-sent model (on both rfa and ifc files they provided) and asked them if they could re-save the file and afterwards the issue was gone.
Prior to this, I have tried opening them from two different pc’s and it wouldn’t load.
2 weeks ago
2 weeks ago
2 weeks ago
Today I learned!
Sure enough, most of the files giving me grief are Revit Mechanical 2010 files.
2 weeks ago
Revit files not being reverse compatible has always been such a...
