Reading out non standard door/window parameters by marker ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2003-11-20
03:57 PM
‎2023-05-24
12:51 PM
Rubia Torres
I am trying to modify a window/door marker to read out additional parameters and show them in the marker.
eg. Fire rating or Acustic rating.
Is there such possibility?
Am i on the right path trying to use:
REQUEST ("ASSOCLP_PARVALUE",[..]) command
but I am trying it with no luck yet...
Anyone tried that?
Regards,
Piotr Dobrowolski
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-11-20 07:10 PM
The trick is to have each parameter listed and accounted for in both the Door/Window Object and the Marker Object. This allows you to pull the parameter value from the Door/Window and repeat the value in the Marker. And be sure to keep the parameter format identical in both Objects.
You could also use the "GLOB_USER_#" to pass the value between objects.
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-11-21 02:34 AM
I tried to use it, but it did not read the parameter - I probably did something wrong ...
In GDL manual there is no example on this command...and the explanation is a bit weired
As weired as the explanation on "moving" hotspots - I figured it out by the examples only ...
So. You probably did some research on the command (I saw Your post on gdl-talk sometime ago) so maybe You would share an example with architalk
Regards
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-12-02 07:42 PM
"REQUEST ("ASSOCLP_PARVALUE", expr, name_or_index,type, flags, dim1, dim2, values)"
- noone noticed that expr - which is for parameters name should be written in quotation marks "expr".
I have found the working example in "object marker" or "object label" so I am rewriting the "WD marker" object to read out the fire and acoustic rating - the key was:
re_fire=REQUEST ("ASSOCLP_PARVALUE", "gs_list_firerating", nameind_fr, type_fr, flag_fr, dim1_fr, dim2_fr, val_fr)
re_acou=REQUEST ("ASSOCLP_PARVALUE", "gs_list_acousticrating", nameind_ar, type_ar, flag_ar, dim1_ar, dim2_ar, val_ar)
val_fr is the value of the parameter "gs_list_firerating" in asociated door / window
Regards,
Piotr Dobrowolski
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-12-02 11:14 PM
Is it working for you?
AC 5.1-25 USA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-12-03 06:36 AM
I did not use REQUEST comand much before.
Regards,
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-12-08 09:16 PM
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-12-09 07:34 AM
http://archicad-talk.graphisoft.com/viewtopic.php?t=648
remember about quoting the parameter to read the value (bug in GDL manual)
I have remodeled the marker to read nominal door sizes and fire & acoustic rating.
Regards,
Piotr Dobrowolski
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-09-05 12:18 PM
I have a problem with WD - marker_22. It doesn't read values out of "gs_list_firerating", "gs_list_acousticrating", "gs_list_heattransfer" or "gs_list_location". I am working on Archicad22_POL, INT has also the same problem. What is this about? Did you have the same problem?
Best regards,
Rafał.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-09-05 05:53 PM
(those values read ok in the default marker)
Piotr
