2011-09-0711:27 AM - last edited on 2023-05-2410:53 AM by Rubia Torres
2011-09-0711:27 AM
Hi. I am trying to create a small custom library of doors, and all is going quite well. I have a problem only with door frame. I can get the frame to read the width of the wall while placing doors, but if I change the width of wall afterwards, the doors do not adjust automaticaly. Is there any simple solution to that? Any GDL command I dont know?
In GDL it is "C_ "or "WALL_THICKNESS" - either will work.
So in your script you need to set the frame depth = C_
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
