Rebuild custom door after wall width change
Hi. I am trying to create a small custom library of doors, and all is going quite well. I have a problem only with door frame. I can get the frame to read the width of the wall while placing doors, but if I change the width of wall afterwards, the doors do not adjust automaticaly. Is there any simple solution to that? Any GDL command I dont know?
1 REPLY 1
In GDL it is "C_ "or "WALL_THICKNESS" - either will work.
So in your script you need to set the frame depth = C_
