Referencing a detail id inside a detail cut
Jeremiah
We have a object that defines the detail drawing area inside a detail cut and I want to have the object put text into the detail cut that references the unique detail cut reference ID. Is there a way I can do this?
8 REPLIES 8
TomWaltz
I've been trying to do this for some time, with no results 😞
Tom Waltz
Does anyone know the GDL call that would allow us to make a library part that could identify the Reference ID of the detail window it was inserted into and display it? We would put this part on a visible layer so that it would display in the view inserted into PlotMaker.
Is there such a call?
TomWaltz
There is an AutoText field in Plotmaker that you can include as simple text
<ACFILENAME> is the name of the PLN/PLP file it came from
<DRAWINGNAMEEXT> is the name of the plan, section, or detail window.
Tom Waltz
Thanks Tom, but we were specifically looking for the Reference ID and not the Detail Name. Any other ideas?
TomWaltz
Do you mean the internal ID used to control referencing Detail Markers, just the Detail number you fill out in the Detail Menu?
Tom Waltz
The number we are filling in when we create an independent detail window...
Jeremiah
My temporary solution has been to do a title type in Plotmaker that uses the auto text feature and calls the id number and name and places it in the correct spot in the title. It somewhat solves the problem. If you would like further info about the title type you can im me (see my profile).
I am off next week. I get back in touch the week after. Thanks!
