Remove the thick dot from the center of the door in plan
Gisele
Hoe to remove the thick dot from the center of the door in plan?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
2 ACCEPTED SOLUTIONS
Todd Thomas
Missing object from a library?
Archicad 26
Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz 4.00 GHz
32GB RAM
Windows 10 Pro
That is a missing object, possibly a door marker.
Check your Library Manager to see what is missing.
Todd Thomas
Archicad 26
32GB RAM
Windows 10 Pro
