Replaced custom 2D object
Llian
I have a simple 2D object in one pen color, line type ...airspace.
Why there is a long list of pens showing up?
When I replaced it with a minor change, I have to go through a list of line, fill and pen types. How to get the list the same as my original object parameters?
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
1 REPLY 1
Hi, Normally when creating objects and you have a fill, 4 pens will default be added:
1. Foreground pen
2. Background pen
3. Outline pen (unless it is disabled on your 2D)
4. Pen no. 3
Then another pen will be added for your lines.
Make sure you don't delete the working elements used when creating the objects as you can edit them and replace the existing when needed. I understand that sometimes the pen arrangements when replacing the object becomes different. The only solution that I could think of is to "override" the object pens if this happens.
Hope it helps.
