Request Override Surfaces
Cosminn
Hello everyone, Is there a way to request the name of Overridden surface of an ArchiCad element, on each faces and edge.
Sincerely,
Daniel
Dontknow
At the selection settings of your element you can override the surfaces.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Cosminn
Thank you Dontknow
Sometimes my english level creates misunderstandings.
I solved my problem, last night. I was referred, how to request it using gdl scripting.
Eg.for Walls -just one face:
qq = REQUEST (WALL_MAT_A , your_mat, get_mat)
Sincerely,
Daniel
Cosminn
Actually the code is:
qq = REQUEST ("name_of_material", WALL_MAT_A, get_mat)
Sincerely,
Daniel
