!Restored: 3 questions......about Zones, Fills, Interior Wizard
Fills: Is there a color fill that will cover furniture but still allow them to be seen (transparent) and other objects instead of allowing them to be above or below the fill?
Zones: is there an option to include thresholds in your zone areas or do you have to individualy manipulate them in when placing the zones?
Interior Wizard: each time I try and add base and chair molding using the interior wizard it creats them over my doors. Am I doing anything wrong here, or is this tool not smart enough to omit the doors when adding these moldings. When I click on the "Use bottom edge" option, it creates the molding up and around the frame of the door which again, is not what I'm looking for.
4 REPLIES 4
Aussie John
What you need are objects where the fill can be turned off.
That said you can have a fill with a transparent background eg only the hatch lines show. Select the background colour to the transparent option ie (ø) in pen colours.
Again this is a function of the door or window object - not the zone. Not all doors are scripted to allow this.
Cheers John
[/size]
Based on this, I've looked for a setting to include thresholds in zones in the standard AC door settings but didn't find anything. Should I have and if so, where? Or do the standard doors not have this?
TomWaltz
i think what you're looking for is under Project Preferences > Zones.
Tom Waltz
Aussie John
yes that is right (was thinking about something else)
One thing I have noticed is it used to work but now doesnt. Anyone else find that (v10 1183aus)
I wonder if it is related to the fact that door schedules no longer recognise room to and from either
Cheers John
[/size]
