Revolving a curved surface
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-02-11 03:15 PM
2011-02-11
03:15 PM
I'm trying to use the Revolve command to sweep a profile around a corner. It seems to work fine apart from a curved part of the profile - it seems to be reduced to a straight line.
Surely it's possible?
My code is:
REVOLVE 11, 90, 63, 0, 0.00, 0, 0.125, 0.0005, 0, 0.1213926683545, 0.02164398987305, 0, 0.1115287291162, 0.02, 900, 80.53767779197, 0, 4001, 0.1115287291162, 0.03, 0, 0.01347127088383, 0.03, 0, 0.01347127088383, 0.02, 900, 80.53767779197, 0.001, 4001, 0.003607331645509, 0.02164398987305, 0, 0, 0.00, -1Screengrab attached showing where the revolve fails.
Is it just a masking code issue, either for the Revolve or one of the points within it?
Thanks in advance.
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
AC19 / 21 / 23 / 27
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-11 04:28 PM
2011-02-11
04:28 PM
It seems like there are too many nodes in the Revolve statement for the element pictured. It looks like it should only need six nodes to define that shape.
The coordinate values are also a bit baffling. I would suggest coding the Revolve with variable parameters for the node coordinates so you can more easily tweak the outcome.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-11 04:55 PM
2011-02-11
04:55 PM
They were generated by ArchiCAD from a fill, so I didn't question them!
And the item won't change in size - it's just on or off, so I have bothered with variables for the various points.
There are 6 points, plus two curved edges. So 6 nodes for the points, another two lines per curve (so 10), plus a return to the starting point - I would've though 11 was correct?
If I wanted an angular profile then 6 points would do the job fine - my issue is trying to get the curved edge to revolve as a curved surface. It works fine on the straight prism (on the right of the screengrab). Any ideas where the error is? I'm sure it's something obvious I'm missing!
AC19 / 21 / 23 / 27
AC19 / 21 / 23 / 27
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-11 07:05 PM
2011-02-11
07:05 PM
It's hard to read the form from the coordinates, but perhaps the center points (mask 900) are messed up somehow. A mask of 1001 or 2001 (tangential to point or by angle) would fix it. In this case you can delete the center point.
I still don't see why you aren't using a profiled wall for this.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-11 08:24 PM
2011-02-11
08:24 PM
Syntax for status code 4000 is
0, ang, 4000 + sIt seems you have inverted ang and 0.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-12 01:44 AM
2011-02-12
01:44 AM
Olivier wrote:Of course! Silly of me not to notice. Thanks Olivier.
Syntax for status code 4000 is0, ang, 4000 + sIt seems you have inverted ang and 0.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-14 11:05 AM
2011-02-14
11:05 AM
Excellent, that's done the job fine - thanks!
The original profile was generated in 2D so I had to invert the X and Y values to get it in 3D - guess I accidentally inverted all the lines.
AC19 / 21 / 23 / 27
AC19 / 21 / 23 / 27
