Roller door
Hi there, how to flip the roller garage door to the other side?
David Maudlin
Farnoush:
Select the Door and use the Rotate command to flip it to the other side.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
cuba
Flip only works for 'normal' doors
Best delete and replace.  Click on the outside of the wall to place the garage door.  (opening will be on opposite site)
Apple M1 Max 32 GB Ventura
AC27
David Maudlin
Farnoush:
Thanks David
