‎2006-03-15 07:38 PM
‎2006-03-20 07:32 PM
‎2006-03-21 05:43 AM
‎2006-03-21 06:22 PM
‎2006-03-21 06:52 PM
Seiss wrote:As you assumed and Peter say's, it's the "Half Round Gable Louver.gsm". It's in the 06 Wood-plastic folder> Louvers and Headers.
If you were to use profiler to make the barrel of the dormer could you trim the vent wall to the barrel? Or is your louvered vent a stand alone independent object not needing a wall? If so where do I find it and other louvers of various shapes that I could wrap into roof vents?
‎2006-03-21 07:28 PM
‎2006-03-21 09:58 PM
Peter wrote:
Seiss,
Since Mark did not answer the question you directed to him
about trimming an object to a Profiler barrel vault, I will.
‎2006-03-21 10:43 PM
‎2006-03-21 11:12 PM
Peter wrote:
Mark,
I had been assuming that the object would not be buried
because it could be cut off at the roof surface using SEO
with the roof as operator.
‎2006-03-22 09:40 AM
‎2006-03-22 10:54 AM
