‎2007-05-11 12:33 AM
‎2007-05-11 02:00 AM
‎2007-05-11 06:14 AM
Jay wrote:You probably have the command in the wrong place. Any code to see?
I added a ROT command to the 3D Script and a xrot parameter. I can not "invert" Simpson bucket (one object) and straps (another object). The 3D selection hotspots do not rotate. Is there a way to have the hotspots also rotate with the object?
‎2007-05-11 08:37 AM
‎2007-05-11 08:37 PM
Aussie wrote:Here is the Code from the 3D ScriptJay wrote:You probably have the command in the wrong place. Any code to see?
‎2007-05-11 08:41 PM
‎2007-05-11 08:42 PM
‎2007-05-11 09:21 PM
‎2007-05-11 09:34 PM
Peter wrote:Sorry for the confusion. I have edited the post to remove the extra "not".
Hello Jay,
I am a bit confused.
You say "I can not "invert" Simpson bucket (one object) and straps (another object)" and then you say
"Is there a way to have the hotspots also rotate with the object" implying that you can rotate the object............Peter Devlin
