Rotating Window/Door Marker Text
I have created a window marker from gdl script. I am able to have the window marker rotate with the actual window, but I can't get the text in the window marker to rotate along with the marker and window. The following is the script I have so far:
unID = 1
HOTSPOT2 locX, 0, unID, locY, 1+128 : unID = unID +1
HOTSPOT2 locX, -1, unID, locY, 3: unID = unID +1
HOTSPOT2 locX, locY, unID, locY, 2: unID = unID +1
HOTSPOT2 0, locY, unID, locX, 1+128: unID = unID +1
HOTSPOT2 -1, locY, unID, locX, 3: unID = unID +1
HOTSPOT2 locX, locY, unID, locX, 2: unID = unID +1
ADD2 locX, locY
MUL2 GLOB_SCALE, GLOB_SCALE
PEN 11
HOTSPOT2 0', 0'-0.0774"
HOTSPOT2 0', 0'
HOTSPOT2 0', -0'-0.0716"
HOTSPOT2 -0'-0.1492", 0'-0.0774"
HOTSPOT2 -0'-0.2014", 0'-0.0029"
HOTSPOT2 -0'-0.1492", -0'-0.0716"
HOTSPOT2 0'-0.1492", 0'-0.0774"
HOTSPOT2 0'-0.2014", 0'-0.0029"
HOTSPOT2 0'-0.1492", -0'-0.0716"
PEN 12
LINE2 0', 0'-0.0774", 0', -0'-0.0716"
LINE2 -0'-0.1492", 0'-0.0774", -0'-0.2014", 0'-0.0029"
LINE2 -0'-0.1492", -0'-0.0716", -0'-0.2014", 0'-0.0029"
LINE2 0'-0.1492", -0'-0.0716", 0'-0.2014", 0'-0.0029"
LINE2 0'-0.1492", 0'-0.0774", 0'-0.2014", 0'-0.0029"
LINE2 -0'-0.1492", 0'-0.0774", 0'-0.1492", 0'-0.0774"
LINE2 -0'-0.1492", -0'-0.0716", 0'-0.1492", -0'-0.0716"
PEN 11
DEFINE STYLE "AC_STYLE_1" "Arial Narrow Western",
8'-1.2222", 5, 0
STYLE "AC_STYLE_1"
If anyone has any ideas on how to fix this I would greatly appreciate it. Thanks,
farrelca
4 REPLIES 4
I don't see any Text2 statement in your script so it's hard to say.
For rotating the text: If you want to keep the text horizontal to the page then you can use:
rot2 -SYMB_ROTANGLE
Text2 0, 0, AC_WIDO_ID
del 1
If you want the text to rotate with the wall this is a little more complicated since you have to correct for when it turns upside down or faces the wrong way.
That's what I am attempting to get to. I have a very limited knowledge on gdl... is this something I would be able to do myself?
Also, the text that appears in the window marker is derived from the I.D. number that I enter in "Listing and Labeling" for each window. Should I change this so it references a Text2 number?
Thanks for your help.
It depends on how easily you can pick it up. The basic code to do this is:
mul2 GLOB_SCALE, GLOB_SCALE
DEFINE STYLE "text_style" "Arial", 2.5, 5, 0
STYLE text_style
Circle2 0, 0, 5/32"
IF SYMB_ROTANGLE > 90 & SYMB_ROTANGLE <= 270 THEN
	rot2 180
ENDIF
The AC_WIDO_ID is the parameter used by the door/window marker subtype to express the ID of the associated door or window.
I don't understand how you can get text to display on plan without the Text2 statement.
What you suggested worked out. Thanks so much for your help.
