Learn more
Chadi SAROUFIM
S)_Renumber
I have a Library part called SO_Renumber, it used to work in ArchiCAD 7 but it is not working at all in ArchiCAD 8.1. Its job is to give automatically consecutive numbers on every mouse click. If you want to insert in-between a new item you would Alt-Click and update.
I am attaching the library part for info and for the the ones who don't have it.
Anyone using it in 8.1?
Chadi Saroufim, Assoc. AIA
M. Arch & M. Urban Design, Partner
Idepconsult – Mounir Saroufim and Partners
ArchiCAD 23 INT
Windows 11
27 Replies 27
Djordje
Remember to zip it before attaching ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Chadi SAROUFIM
I thought I had attached the file but it seems I did not go through so here it comes agiain.
It is very very small. Zipped or not will not make any difference.
ArchiCAD 23 INT
Windows 11
Oleg
Interestingly, this object was written by me for a long time ago. I did not think, that it is used by someone.
I have found it on my disk and it seems works on 8.1R2+
I do not know the reason why it does not work for you.
For work of object it is required also master_gdl.gdl which was with it together.
PS:
I am not sure as i use Administrator privileges, but as the object uses DATA IO, may be you should have the OS user privileges on creation and writing of files in ArchiCAD folder.
Oleg,
In the SO_Renumber.LIB there are two files with
file extensions *.gd& and *.gs&.
What kind of file types are these ?
I did a search in Archicad Help and came up with nothing.
If the part uses DATA IO does something have be put in
what was in AC 6.5 called "Archicad data folder" ?
If so what is the name of the corresponding folder
in AC 8.1 v2 ?
Thank you,
Peter Devlin
Oleg
Peter wrote:
Oleg,
in AC 8.1 v2 ?
Thank you,
Peter Devlin
You can delete all files excluding SO_Renumber.gsm and Master_gdl.gdl
gd& and gs& files are precompiled scripts on the Windows platform. They are created automatically by ArchiCAD.
DATA IO uses by default ArchiCAD root folder (instead of "ArchiCAD Data Folder" for TEXT IO).
You should not put any files into it. Two files will be created by the object automatically.
The note:
I do not know why Chadi writes about Alt+click. As far as I remember, for renumbering elements (after deleting for example) it is required to use Alt+Rebuld.
Besides this object was something like idea to share for GDL developers (One more same object was SO_Animation). Though it was working object, I am not sure in its practical utility.
Oleg,
Thank you for your reply and the information.
If the object does what Chadi says it does
it's utility would be, for example,
automatic consecutive door numbering and
automatic updating of all door numbers when
a door is added or deleted.
I have always wished for something that would
do this but could not figure out how to do it.
Thank you again,
Peter
Aussie John
On a simpler level, you can do this with the ID of the object display a number via the command "text2"0,0,glob_ID" and the preference set to show consecutive numbering.
Cheers John
[/size]
Hello John,
Been there,done that, (as they say).
I have gotten Oleg's library part to work very well for deletes.
It de-increments all the numbers higher than the one deleted
when you use opt/alt + rebuild and regenerate.
I wonder if and how I can get it to work with an addition of a
number in the sequence.
I am forever forgetting to number one or two doors in the plan
and have edit every door number to correct the sequence.
Regards,
Peter
Djordje
It does, as ZIP is in the list of allowed extensions ...
Djordje
HP Omen
