Yvonne
Sashless double hung window
Is it possible to model sashless double hung window with AC26 windows? Specifically the Aneeta Windows https://aneetawindows.com.au/products/
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
1 Solution
Lingwisyer
Guru
Not with the default library. For a while I was using a two panel vertical multisash window with one set to top hung. Elevation wise, with the default windows you can basically zero the width of the sash frames, but you cannot modify their depth, so it looks a odd in 3D... Ended up giving in and using 4D windows for them...
If you only have a few of them, your best option is probably to model them on the floor plan and save them as custom windows.
Go to post
1 Reply 1
Lingwisyer
Guru
