‎2006-10-02 04:41 PM
‎2006-10-02 04:46 PM
sirduncan wrote:I don't believe there is any way to "save down" an object.... I don't believe there ever has been. I do not even know if there is any kind of hack (like Bin/Hex editing) that you could even use to sidestep this.
This is not good. Someone please tell me that there is a method to save objects in 10 and make them usable in 9 and vice-versa.
‎2006-10-02 04:50 PM
‎2006-10-02 05:08 PM
‎2006-10-02 05:53 PM
‎2006-10-02 07:43 PM
sirduncan wrote:Yes, you need to edit library parts the the oldest version in which they still need to be used. Once saved into a new version the only way to convert them back is to copy paste the scripts and recreate the parameters (or find a backup copy).
So do I need to develop my objects in 8.1 so that they can be used in 8.1, 9 & 10? And will they be useable in those?
‎2006-10-02 08:36 PM
‎2006-10-04 09:34 AM
‎2006-10-05 10:28 AM
sirduncan wrote:There is another solution, but it requires a bit of command-line babble. ArchiCAD has a tool to convert objects to XML and back again. You can convert objects to XML from one version and then convert them back to objects of another version. Bear in mind that new GDL features in recent versions still won't work in earlier versions, but no problems if you stick to instructions which are common to all versions.
‎2006-10-05 12:22 PM
