Mik001
Saving New 3D Object
I am trying to create a 3D object from a .dwg file that has contours in it at 1m height intervals. I can get it into imported into ArchiCAD no trouble. But when I try to save the 3D object I get an error message saying 'To save this object in version 28, you must choose a License on the Details page'.
Does anyone have any idea what this means and how to get through this? I have a full license for AC 28 so am quite confused why it is asking me for my license number...
10 Replies 10
It is the type of licence for the object not your actual Archicad license.
In the DETAILS tab of the object ....
Mik001
Thanks Barry,
I feel like a bit of a dope, but it is my first time making a 3D object.
If I may ask, because this is technically surveyors data (3D contours), I am guessing now that as a placeable object it has lost its original coordinate system so cannot be place in its original geolocation? Is it possible to maintain the z values for the contours in a .dwg file while importing, but still retain the correct geospatial location information so it can be stacked with other georeferenced .dwg files such as land parcels?
Also another question, back in the 2D window, I am unable to use the level dimension tool to establish what height the contours are at. I think I am using the wrong workflow here...
We all have to learn some thing new.
When saving as an object, it will be in the position it was from the project origin when you saved it.
In all directions, X, Y and height (Z) - at least I think so, I have never tried with survey data.
It will have lost any geolocation data, but you can of course move it to anywhere you want.
Because it is an object, the dimension tool will not link to the surface.
You will need to keep it as a mesh to be able to use the dimension tool.
You can import as a mesh using the 'Place mesh from surveyors data' command.
You will need a text file with the XYZ coordinates.
If you don't have it I remember reading a post here somewhere about extracting that data from the XYZ file.
If I get a chance later I will try to search for it.
Lingwisyer
Guru
Do note, that if you import surveyor data by their origin, you will often end up very far from Project Origin, which AC very much dislikes and will cause you many issues.
Ling.
Mik001
Yes, I've noticed that. I am curious though if it's possible in AC to simply drop in (xref) georeferenced files with respect to the origin, place a hotspot where the origin was, and then move the origin closer to the georeferenced file? Then, when the surveyor needs to go and stake out the building etc, move the origin back to its original position so they have the correct georeferenced coordinates for staking out in the dwg file. Would that work? Just curious how to retain the very valuable georeferenced coordinates within AC without causing issues due to large distances away from the project origin?..
Lingwisyer
Guru
Use the Survey Point to offset it.
I am no expert on this as I don't use it.
But you need to keep the model close to the origin as Ling has suggested.
There is a 'Survey Point' that you can place where the survey should be that will allow for geolocation when you share files with other software.
But as I mentioned, I really don't know how this all works as I never use it.
Mik001
Tell me if I have this right. After dropping in the georeferenced xref files so they stack correctly, I then move the entire project somewhere near the project origin. Then I activate the survey point, at which stage I need the Easting and Northing values (from the surveyor I'm guessing) to input into the coordinates box. When I save out or export the file, I use export with survey point and not with the project origin. Is that correct?
I'm just quite confused as to how the drawing remains correctly georeferenced after the project is moved closer to the project origin.
Please forgive these basic questions, I have not used the survey point for georeferenced files before.
Lingwisyer
Guru
I have never used it in AC either, but yeah, export by survey point. I assume it remains correctly georeferenced as the coordinate you put into the survey point offsets the distance to project origin. That is what is suppose to do anyway.
https://help.graphisoft.com/AC/29/INT/_AC29_Help/020_Configuration/020_Configuration-37.htm#XREF_822...
Ling.
