‎2004-07-0706:31 PM - last edited on ‎2023-05-2611:46 AM by Rubia Torres
‎2004-07-0706:31 PM
Hi all,
Is there any way to insert a blank row in a schedule. A door schedule specifically. I would like to insert blank rows where door numbers, not being used, can be placed. Is this possible?
Thanks,
Robert J. Garand ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
I can imagine listing an item the value of which is a zero-length string. For example, you can set the User IDs of Doors to nothing and list those.
Alternately, you can go to the Property Script of each door and define a Descriptor like this
DESCRIPTOR ""
Then in Setup List Schemes go to the Properties & Parameters page and select Object-specific items only from the Descriptors field.
Laszlo
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
