Red
Screened Porch
I'm searching for an object that I could use for a screen porch. Does anyone know where I could find one?
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
20 Replies 20
David Larrew
Are you looking for a whole porch Object (floor, columns, roof, screen panels, etc.)?
Or are you asking how to build a porch from individual components using Walls, Columns, Slabs, etc.?
Or are you looking for an object to use as the screen panels?
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Red:
Do you really need a Library Part ?
If the screen is visiblke only in elevations drawings, a fill may be all you need.
If you needed for a 3D model, you may need to create a new material using the Glass material as a basis and adding some sort of a texture. (Just a suggestion, I have not tried this)
Conrado
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
Hi Red
I use the technique Conrado suggests, it works great in the 3D model but you lose it in rendering unless you have a good texture. The only textures I've found acceptable for this has been for safety glass with the "chicken" wire in it, screens have been tough because I've never been able to illiminate the backrounds in the textures.
Dwight
To make a convincing porch screen, edit glass by adding a high-resolution noise texture with an alpha channel mask to knock out some background.
Increase the opaqueness of the glass until it all works.
Take out the green color of the glass - make white if aluminum screen and black if nylon.
For shiny screen, make the specular reflection of the material high.
Dwight Atkinson
Red
Or are you looking for an object to use as the screen panels?.
Yes just the object itself.
By the way thanks for all the help guys. I will give that a try Dwight
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Red
After Dwight mention tweaking the settings of the glass material I think it turned out perfect. Heres an attached file showing the settings with the finished product.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
You've got it, Red.
If the camera might be close enough to the screen that the viewer would (should) see the screen mesh texture - make an alpha-mapped screen mesh and load that texture into your material.
Have fun,
hi red,
i tried the settings you gave me, but it doesn't show up at all. it kind of shows up in the materials settings, but when i go to the 3d view, it's totally gone. i even took the transparency way down. i had to take it 30 before it showed up and then it went to total black. any ideas?
Dwight
Post your material settings and your rendering settings.
Dwight Atkinson
