Script windows do not hold thier position
Has anyone noticed that in the GDL editing environment in AC 10
the size, position, and font selection of the script windows are not remembered from one session to the next.
These prefs used to be stored in the "dialposition prefs" but
apparently now they are not remembered.
If anyone can confirm this I will report it to GS.
Thank you,
Peter Devlin
11 REPLIES 11
David Maudlin
Peter:
Just as you describe, plus the font size is not saved. I know most will not notice, but a big pain when doing library revisions. I hope this is a quick and easy fix.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
I have always had this problem. It's usually related to moving work between machines, in my experience.
The report window also resets its size/position at the same time. Which is annoying for me because it sits behind my Navigator. Extra credit peeve: Why is the default size of the report so small? It doesn't even show the full width of text.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Thanks for the verification.
I will report this to GS.
Peter Devlin
Jefferson
Hi Peter, James -
Off topic here, but perhaps this is related and you can explain what this is about [see attached], the preview for my favorites windows are coming up with very strange liner, or that's my interpretation anyway, preview display. Yet when placed they are as they're supposed to be. Kind of a what the sort of thing. As well the thickness of the liners keeps reverting to 1/2" after setting custom thickness to 3/4". I thought perhaps you GDL guys might have seen this, and/or have some input to correct it, or just live with it.
I get the feeling I'm just not supposed to understand it all and just keep moving forward but.........
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
Hello Jeff,
I am not sure what you mean by the term "liner".
What I see in your image of the preview is a rather
large jamb depth. AC displays the window before
it is placed using the wall thickness from the current
thickness of the wall in the wall tool.
After you place the window then the preview
shows the jamb depth as it is in the host wall.
You may have the wall thickness in the wall tool
set to a large dimension like two feet but none
of your placed walls are that thick.
Just a guess.
Peter Devlin
Peter wrote:
Just a guess.
That's it. Same as in the object editing plan & 3D windows.
James Murray
Jefferson
Thanks gentlemen! That was it! I had a "custom" extra thick wall I was playing with previously as the default wall setting, so a 3'-6" jamb appeared. Doh!!! I didn't realize the default wall tool was linked to the window preview. And the education never ends!
Now for my really stupid question, I cannot find the parameter, or at least the equivalent to "wall thickness" from my 8.1 window dialoge box? Even though I apparently already have it set.....
Plowing through the PDF AC_10 Illustrated windows, a search for wall thickness netted me jamb extension as you've both suggested, however changing his setting has no appropriate results in the jamb extension preview appearance, for this pilot anyway............I really am trying here, which means it is RIGHT IN FRONT OF ME, but I can't see it. Can you guys bare with me a bit longer and help me find the settings [or equivalent], I'm after, please + thank you! Perhaps a screen shot?
Peter, I haven't forgotten you, just getting it together.......
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
Jeff,
Apparently, AC 10 windows and doors do not have
the "Frame depth" with the note "0=wall thickness".
In the parameters under "Frame" there a parameter
called "Frame depth" that can be set manually to
the thickness of the wall it is in but does set itself
to the wall thickness automatically if you make this
parameter equal zero as in previous versions.
The jamb extension adapts to the wall thickness.
Just more things to set before one places a window or door.
Peter Devlin
Jefferson
Hey Peter -
Thanks for getting back to me. That was the setting I'd found, and been adjusting as if it had an effect. Of course with the "auto-depth"actually in effect, it went right on by me. In 8.1 + 7, I had always set the depth to automatic, [or somehng of that sort], not 0", and let AC do the math, which sounds as though both had the same effect. Looks like it still does, just by different terminology.
Adjust and adapt.........
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
