Scott Bulmer
Section Marker Head Text Alignment
In Section Marker_NCS 14 or the Built-In Section Marker, is it possible to adjust the text alignment away from the horizontal dividing line separating the first and second rows of text? To my eye the appearance has always been too close and I have never been able to figure out how to adjust it.
Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
12 Replies 12
Erich
Scott,
This is accomplished by changing the value of the ii variable defined in the code. For one case it is defined as a value of positive 1 and in the other case as negative 1. If both texts are moving in the same direction then you are using the same sense in both cases.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Scott Bulmer
Erich, that was it, it works!!!
Thank you so much. I don't know why GS does not include your coding with this part as without it, it does not look very good.
Much appreciated,
Scott
Erich
Scott,
Perhaps a bit painful getting there but I am glad this worked for you in the end.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
