‎2009-11-25 03:40 PM
‎2009-11-25 05:41 PM
‎2009-11-25 07:13 PM
‎2009-11-26 07:08 PM
Erika wrote:And this is what got implemented in AC13 Library for objects usually not on the floor (basins, cooktops, etc.). It lets you level elements by default in your library. E.g. leveling of a cabinet element (parameterized by ZZYZX) and a cooktop element (where ZZYZX is its thickness).
Or you could add a custom parameter that will allow users set the insertion height of the object.
‎2009-11-27 10:49 AM
‎2009-11-27 11:44 AM
derekjackson wrote:A new parameter got introduced in every naturally elevated object. The name varies on the use. It can be countertop height for objects which are inserted into the countertop. It can be top height for objects which are usually placed by their top level - e.g. wall hung basins or toilets. You can see one more advantage here in contrast to a simple elevation. The library developer can choose the vertical leveling point for the object. It can be anywhere not just on the top or bottom - like the
And what is it about AC13 that allows this - an extended set of variables in GDL script?
