2010-08-04
11:10 PM
2023-05-24
11:53 AM
Rubia Torres
2010-08-05 11:08 AM
2010-08-05 01:32 PM
2010-08-05 08:42 PM
2010-08-05 09:22 PM
Peter wrote:The hole-cutting is managed by an add-on. You can't do it with GDL. The add-on simply monitors the placement and editing of object of a particular subtype and manages the hole placement accordingly.
Does anyone know what GDL command cuts the hole ?
2010-08-06 12:26 PM
Peter wrote:Yes, that would be interesting if you can obtain the A and B parameters of the roof hole.
Hello laszlo,
I suppose one could script fill bodies like we
did for non-rectangular windows and doors
before the wallhole command was introduced.
Thanks,
Peter Devlin
2010-08-06 12:43 PM
laszlonagy wrote:The hole-cutting is performed by an add-on, i.e. using the ArchiCAD API via C/C++. You can't do this with GDL, and hence it won't be possible to control the edges etc.
What I don't know is whether you can make the edges of that hole disappear ( set their status to hidden, like you could do it with wall holes). If you can do that, then I guess it is feasible.
2010-08-07 04:21 AM
2010-08-10 02:22 PM
