And7777
Sliding aluminum doors with bottom track.. does this exist???
Am I missing something? But why does ArchiCAD still not provide a sliding external glass door without with a bottom track/frame?
In most countries around the world it is standard that an aluminum framed glass door or even a timber framed glass sliding door has a bottom track. I am trying to use the doors provided in ArchiCAD without going to third party CAD doors.
It seems an extremely basic option to provide a bottom track without having to trick the software with thresholds. Has anyone heard anything or discovered something I'm missing?
1 Reply 1
Guru
I added a basic sill to a bifold by adding a new BLOCK and WALLNICHE to the 3D script of the top level object. You could possibly do the same if need be if you know some basic GDL.
Ammended Master
!===================  UI Pages  ===================
TABID_ROOT = -1
tabIDx = 1
TABID_GENERAL		= tabIDx		: tabIDx = tabIDx + 1
3D Script
DEL TOP
Addx -a/2
ADDz gs_sill_ovhg_left + gs_frame_thk - gs_sill_thk
	IF gs_trim_outside then
			Addz -gs_trim_thk_out
		ELSE
			gs_trim_thk_out = 0
	endIF
	IF gs_trim_inside then
			Addz WIDO_SILL
		ELSE
			gs_trim_thk_in = 0
	endIF
		MATERIAL gs_frame_mat
		Block A, gs_frame_width, gs_sill_thk !gs_frame_thk + gs_trim_thk_out + gs_trim_thk_in
	IF gs_trim_onside then DEL 1
	IF gs_trim_outside then DEL 1
DEL 1
!==============  Wall Hole  =================
PEN WALL_VIEW_PEN
SET MATERIAL WALL_MAT_B
WallNiche 4, 1, 2,
	0,	0,	1,	-WIDO_SILL,
	0,	0,	15,
	A,	0,	15,
	A,	B,	15,
	0,	B,	1
SET MATERIAL WALL_MAT_A
If WIDO_SILL <= 0 then
	WallHole 4, 2,
		0,	0,	15,
		A,	0,	15,
		A,	B,	15,
		0,	B,	1
endIF
WallNiche 4, 1, 2,
	0,	0,	1,	WALL_THICKNESS,
	0,	0,	15,
	A,	0,	15,
	A,	B,	15,
	0,	B,	1
Parameter Script
IF GLOB_MODPAR_NAME = "gs_sill_thk" | GLOB_MODPAR_NAME = "gs_frame_thk" | GLOB_MODPAR_NAME = "gs_sill_ovhg_left" | GLOB_MODPAR_NAME = "gs_sill_ovhg_right" then
	IF gs_sill_thk < gs_frame_thk + gs_sill_ovhg_left & gs_sill_thk > EPS then
		gs_sill_thk = gs_frame_thk + gs_sill_ovhg_left
		PARAMETERS gs_sill_thk = gs_sill_thk
	endIF
endIF
IF GLOB_MODPAR_NAME = "gs_trim_outside" | GLOB_MODPAR_NAME = "gs_trim_inside" | GLOB_MODPAR_NAME = "gs_sill_thk" then
					gs_sill_thk = WALL_THICKNESS
				ELSE
					gs_sill_thk = gs_frame_thk + WIDO_SILL
			endIF
		ELSE
					gs_sill_thk = WALL_THICKNESS - WIDO_SILL
			endIF
	endIF
	!VALUES "gs_sill_thk"	range[WALL_THICKNESS,]
endIF
Interface Script
tabIDx = tabIDx + 1
TABID_RETURN			= tabIDx		: tabIDx = tabIDx + 1
ui_page TABID_GENERAL, 100, `Sill`,  "uiTab_Style_hl(1)"
gosub "pageGeneral"
!ui_page TABID_RETURN, TABID_ROOT, `Return Settings`,  "uiTab_Style_hl(1)"
!gosub "pageReturn"
"InterfaceEnd":
END
"pageGeneral":
unL = 1
IF gs_trim_outside & gs_trim_inside then
		ui_outfield			"Exterior Overhang",	10,		15+25*unL,	150,	20,	1
			ui_infield{2}	"gs_sill_ovhg_left",	170,	11+25*unL,	80,		20		: unL = unL + 1
	ELSE
		ui_outfield			"Sill Depth",	10,		15+25*unL,	150,	20,	1
			ui_infield{2}	"gs_sill_thk",			170,	11+25*unL,	80,		20		: unL = unL + 1
endIF
ui_outfield			"Interior Overhang",	10,		15+25*unL,	150,	20,	1
	ui_infield{2}	"gs_sill_ovhg_right",		170,	11+25*unL,	80,		20			: unL = unL + 1
return
Ling.
