Robby
Sliding window and door direction opening arrow not showing.
There is no opening direction arrow for sliding doors and windows in AC28?
I have tried the MVO and the doors and windows are set to symbolic but still don't show whether windows or Mac.
My template or archicad - see image- still no arrow- anyone have a solution or workaround?
Rob Marelli
AC 28.1
MacBook Pro (2023) M3 Max -48 Gb RAM - Sequoia 15.3.2
2 Solutions
rakurs
Have you checked here? There are some more options if you scroll down.
ArchiCAD 28 | INT - Cro | Forward | WIN 10 / 11
Go to post
rakurs
Yes, they do. I don't have any sliding windows at the moment.
The sliding door (at the bottom left) has the following relevant settings:
I will not paste absolutely all of them but if you need a few more, of course I will. With this object, Multipanel sliding door, which was the part of the Library Update 1, we finally got a useful tool for the type of sliding doors we use in practically every project.
Go to post
8 Replies 8
rakurs
Robby
Thank you for the reply.
Yes I have but it does nothing - see pic
Rob Marelli
AC 28.1
Robby
Do your windows and doors show direction arrow?
Rob Marelli
AC 28.1
rakurs
rakurs
This object works nice, and it can even show a half-opened door on plan (or 3D) as expected, if you change the 2D/3D opening length. The arrow moves with the sliding part, too.
(EDIT: I pasted another picture to show another door with a slightly different size next to it, and their respective markers.)
Robby
Thank you!
So the international doors have arrows but USA doors dont- I see. That was the problem.
Rob Marelli
AC 28.1
Robby
Here is the international door and window image:
Thank you very much for your help!
Rob Marelli
AC 28.1
rakurs
I'm glad you found the root cause of your problem. Please send a bug ticket to Graphisoft or the firm that sold you ArchiCAD. It's much more likely it will be addressed that way.
