2018-03-06 02:42 PM
Solved! Go to Solution.
2018-03-14 11:17 PM
!!!Plate 1:40 Plate nr. 1 and 2 !============================================================================================================ FOR i = 1 TO NUM PEN Linje1 sect_attrs{2}Linje1 SECT_FILL Fyll, pen_t, pen_g, pen_b MATERIAL smat IF i MOD 2 # 0 then if Plate_type = 1 then call "Plate_macro" parameters ZZYZX = 0.02, v = 1.43, ac_bottomlevel = 0.060, X1 = X1, Y1 = Y1, B = B endif endif !!!Plate nr. 2 !!ADDY AV1 PEN Linje1 sect_attrs{2}Linje1 SECT_FILL Fyll1, pen_t, pen_g, pen_b MATERIAL smat if i MOD 2 = 0 THEN if Plate_type = 1 then call "Plate_macro" parameters ZZYZX = 0.05, v = 1.43, ac_bottomlevel = 0.060, X1 = X1, Y1 = Y1, B = B endif ADDZ 0.060 endif !!ADDZ 0.060 ADDY AV1 Next iAlso, you should change your "NUM" parameter to an integer type.
HOTSPOT2 0,0 unID = 1000 HOTSPOT2 0, 0, unID, B, 1+128: unID=unID+1 !!! BASE HOTSPOT2 0, B, unID, B, 2: unID=unID+1 !!! Move HOTSPOT2 0, -1, unID, B, 3: unID=unID+1 !!! Ref unID = 2000 HOTSPOT2 0, 0, unID, X1, 1+128: unID=unID+1 !!! BASE HOTSPOT2 X1, 0, unID, X1, 2: unID=unID+1 !!! Move HOTSPOT2 -1, 0, unID, X1, 3: unID=unID+1 !!! Ref !unID = 3000 !HOTSPOT2 0.600, 0, unID, Y1, 1+128: unID=unID+1 !!! BASE !HOTSPOT2 0.600, Y1, unID, Y1, 2: unID=unID+1 !!! Move !HOTSPOT2 0, -1, unID, Y1, 3: unID=unID+1 !!! Ref project2{2} 3, 270, 2Hope that's what you are after.
2018-03-07 09:24 PM
2018-03-12 08:45 AM
2018-03-12 09:20 AM
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2018-03-12 09:44 AM
2018-03-12 09:52 AM
2018-03-12 10:19 AM
2018-03-12 10:44 PM
2018-03-14 06:41 AM
!!!Plate 1:40 Plate nr. 1 and 2 !============================================================================================================ !!!Plate nr. 1 FOR I = 1 TO NUM PEN Linje1 sect_attrs{2}Linje1 SECT_FILL Fyll, pen_t, pen_g, pen_b MATERIAL smat if Plate_type = 1 then call "Plate_macro" parameters ZZYZX = 0.02, v = 1.43, ac_bottomlevel = 0.060, X1 = X1, Y1 = Y1, B = B endif ADDZ 0.060 ADDY AV1*2 Next i Del top !!!Plate nr. 2 ADDY AV1 FOR K = 1 TO NUM2 PEN Linje1 sect_attrs{2}Linje1 SECT_FILL Fyll1, pen_t, pen_g, pen_b MATERIAL smat if Plate_type = 1 then call "Plate_macro" parameters ZZYZX = 0.05, v = 1.43, ac_bottomlevel = 0.060, X1 = X1, Y1 = Y1, B = B endif ADDZ 0.0 ADDY AV1*2 Next K
2018-03-14 11:17 PM
